Question Using 12v Wall Wart to drive 12v motor using RPi
Aug 30, 2022
16
I am using a RPi to switch a relay on and off at certain times of the day. I have an electric motor connected to the relay and would like to use an external 12V DC power supply (wall wart) that I have lying around to drive a 12V DC motor. I have measured various 12V DC power supplies and all of them show >12V: The nearest was 15V and one was 21V. Is that normal? More to the point is it an issue for the motor? LMK if I need to provide more info.
How important is the exact RPM of the motor?
You were measuring the no-load voltage. You would have to put load on the wall wart to see how much the voltage drops.
The motor is connected to a peristaltic pump which I will be using to dose fertilizer. So, RPM not that important as I plan to try and calibrate dosing amount of time the motor is running.
Power supplies come in with different internal resistances. The higher resistance the higher open circuit voltage. Also with the higher resistance will be higher Supply noise. In your case it is just a matter of how many times the motor will rotate to get the dose that you desire. So it doesn't really matter which power supply you use, just calibrate it to dosage that you want.. The power supply that has the higher internal resistance will have more error. Can you tolerate that?
Personally, I would use the cheapest power supply just to get that power supply out of my stack of power supplies. That is, if it works.
OSD
