using 6 pin connectors from the same wire for GPU
jeremys73
21
Hi All,
Putting together a computer for my son and the graphics card has two 6-pin power connections. The PSU has 2 6-pin connections but they're running off the same line from the power supply. Will it work if I plug them both in or do I need to look for another power supply?
PSU: xfx pro 550w
GPU: sapphire r9 380.
Now that it's all put together the system doesn't seem to be recognizing the graphics card which is weird because the monitor is plugged in to it and I'm getting a picture. Looks like it's defaulting to the onboard graphics. I've seen a couple suggestions about changing the option in the bios but I can't seem to find that option. I can get in to the bios but I'm not seeing anything that looks graphics card related and the manual is not helpful.
Mobo: asrock h97 anniversary
Looks like user error, not sure how but the driver never installed the first time around. Thought I installed it but obviously not. Working fine now that it has a driver, go figure.
