I've just bought a new computer to spend the Easter break thrashing out some gaming and just as I finished assembling it I've discovered I only have a single 6-pin PCI-E power cable left while the card has a socket to accept an 8-pin cable. The documentation that came with the card is very sparse however the back of the box does state in small writing "Minimum 500W or greater power supply (with one 8-pin PCI Express supplementary power connector)".
I have tried to both call and email the shop from who I bought the components from however they have not answered/replied and they are unlikely to do so till the end of the break. I am extremely disappointed as I very much want to play with this system over the Easter break myself (that's exactly why I bought it at this time) so want to know if it will be okay to simply plug the 6-pin cord into the first 6 ports of the 8-pin socket.
Specifically the graphics card is a GeForce GTX 1070 WINDFORCE OC 8G card and the case I unwittingly bought is a Versa H23 with 500W Power Supply. The store I bought it from confirmed everything I ordered was compatible however I am not at all confident these components are.
Thank you for you help,
Slarti.
Slarti.
