Greetings
I have this PSU and an RTX 3080Ti already installed using one of these cables
Now I want to install a second RTX 3080Ti, I've seen around that it's recommended to use two 8pin cables instead of 1 cable like the above (that branches into 2). So my questions, if some one could please help, are:
1. do you confirm it's safer to use 2 cables? (mind the already installed GPU is connected only with 1)
2. assuming above answer is YES: can I use a cable like the above, but only connect one end to the GPU -and use a second 8pin cable?
Thanks in advance!!
Thanks in advance!!
