Question using a 32000mhz with b250
.valkyrie.
485
7
10,795
hi.
i have a 32gb kit 3600mhz Gskill royal and a pair of 16gb , 32000ramos.
(2nd pair is my choice on this boundel)
i know 6th gen works on 2133mhz.
but can i OC rams to higher frequency?
like what we can do on 12th fen and 5333mhz? (ofc ram also should support that)
whats the highest frequency that i can run those ram on?
which CPU and exact motherboard model?
the ram will do 3200mhz together, if you're lucky 3600
but the CPU and motherboard is essential
i3 6100
and asus b250 mining expert. though never used in a mining rig.
so you are saying it can go higher than 2400? should i just enable xmp or should i modify it myself?
