Using a ASUS vg248qe on Console? Need Help
Nickoli
Sorry if wrong section but it is my first post. (Basic tech knowledge)
I just got a Xbox one and i have the VG248qe on the way and i know consoles can not utilize the 144hz so im wondering what setting/option i should look at to get the most out of the picture and low input lag, and any other recommendations?
Is there a option for 60hz and im not certain but i read some where a while back that the 60hz will produce a more vibrant color.
Kind Regards
The 144Hz option on the monitor still has pretty vibrant colors, but you're correct, the consoles won't utilize the 144Hz because the monitor can only do that over Dual-Link DVI or DisplayPort.
The monitor runs at 60Hz by default for consoles (I had my PS3 hooked up to my VG248QE for awhile) and the colors generally look fine at 60Hz, you can mess with them using the on screen settings on the monitor if you aren't happy with them out of the box.
As for input lag, you shouldn't have to configure anything to keep input lag low, the inherent response time of the monitor is fairly low, just choose the setting that gives you the colors you like the most, tweak if necessary, and happy gaming! :)
