Using a hard drive formatted in a external enclosure internally
Jun 18, 2018
So i have bought a 2TB hard drive than i plan to put into a external enclosure and format it to use as a external hard drive at least temporarily while i move files off another external drive which has a faulty USB port.
If in the future i want to connect the drive to my PC and just use it as second internal drive (just for storage not to run a OS on it) will it just show up with all the data still there or would i have to re-format the drive from scratch and lose all the files.
This depends on particular external enclosure. It may use some non-standard partitioning of HDD. Then you'd have to repartition/reformat HDD after moving it to PC internally.
Why would would connecting it to a tv cause an issue?
