V Vikas Singh Reputable Jan 7, 2015 3 0 4,510 Jan 7, 2015 #1 hello guys, my question,i am using my adapter directly to laptop without battery for 20 hours.what are the chances of its failure?
Solution ThatVietGuy Jan 7, 2015 I was using the adapter without the battery on my laptop for 8 months and nothing was damaged - what does that tell you?
G Gttrz97 Honorable Jul 1, 2013 96 0 10,660 Jan 7, 2015 #2 none. you wont wear out the battery. Upvote 0 Downvote
V Vikas Singh Reputable Jan 7, 2015 3 0 4,510 Jan 7, 2015 #3 wont that damage the adapter,if i continuosly use that for long hours? Upvote 0 Downvote
ThatVietGuy Titan Nov 6, 2007 11,726 319 70,240 Jan 7, 2015 Solution #4 I was using the adapter without the battery on my laptop for 8 months and nothing was damaged - what does that tell you? Upvote 0 Downvote Solution
