I am wanting to power my xbox 360 slim and play it while the car is in motion. I like to play it in the car while we are on long road trips. I have a simple 150w inverter that plugs into a 12v socket. I was able to plug my xbox into that inverter and it powered my xbox. When I would play the xbox for about an hour, both the xbox and the inverter would experience extreme overheating to the point where my xbox wont power on until it is cooled or the inverter wont work until it is cooled down. The inverter was given to me by my mother and I simply hooked everything up to it and played, but I now know that I was dumb for not looking into it to see if it would cause problems. It powered the xbox, so I assumed it worked just fine. Now I am trying to look for a proper inverter and how I can hook one up to my car (and please dont bash me over my ignorance).
But anyways, here is what I have gathered:
My xbox will require about 370w to 470w and will draw 3.7 amps.
My screen that I use runs of off DC and draws 0.8 amps. This doesnt need an inverter since I can plug it into another 12v socket.
My car manual says that the 12v sockets can handle a maximum of 10 amps. It doesnt say anything about a watt limit.
From my understanding, I will need an inverter that is around 500w. I have looked around for an inverter about this size and was around $50. I found one at home depot that was 500w. The inverter sayed that it will only be 100w if plugged into a 12v socket, but it will be 500w when hooked up directly to the battery. I decided not to buy it.
Now here is my big question: Is there an inverter around 500w that I can plug directly into a 12v socket? OR is it possible to hook an inverter up to the battery when the car is in motion? I am thinking that there could possibly be a way i could string the cables from the battery to the cabin of the car where I would plug things into the inverter.
Any help is appreciated!
(And just to clear this up, I am well aware of the risks involved with the xbox scratching up disks. I actually dont use disks though, I have all of my games downloaded onto the hard drive. And i already have a well ventilated area in my car for my xbox).
