[SOLVED] Using a single DP cable to connect to 2 monitors?
Apr 23, 2020
4
I have a laptop with a DP mini 1.4 connected to a Samsung 27" SR75 Space Monitor. I like this monitor a a lot, and I'm debating on getting a second one for a dual monitor setup. The mintor only has 1 HDMI and 1 DP mini. Would there be a way to connect to both monitors using DP exclusively? I'm trying to avoid using both HDMI and DP because I heard there are possible syncing issues when using 2 different cables. If that is incorrect about the syncing, please let me know!
Thank you in advance to everyone 😊
There's no such thing as syncing issues with different cables. Unless the terminology was unclear, that's the first time in decades that I've heard of the issue. You could always use different cables.
Latest posts
