Hi all,
i have a lot of electronics inside a cabinet in my living room.
i want to connect some fans in its back for more efficient cooling (peaks at around 59 C but i don't want to risk it)
my plan is to use a standard PC case fan connected to the back of the cabinet.
the simple solution would be to use s standard thermostat for ON/OFF running mode.
the thing is... i want the fan the be able to run at different speeds.
so what i need is a recommendation to a thermostat that regulates voltage according to measured temperature( more heat ==more voltage)
any recommendations?
thanks
thanks
