Using a USB Device
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.windowsnt.terminalserver.client (More info?)
I am running W2K Terminal Services which my clients connect to using Wyse Winterms. I have a series of USB scanners which I now need to install around my offices for users to scan with. However, I was under the impression that there is no way to run a USB scanner through thin client. Is this true? Is there any way I can operate my scanners through a terminal services session?
This is not natively supported in Windows TS.
Possible solutions:
RemoteScan from http://www.remote-scan.com/
lets you share any kind of TWAIN scanner (SCSI / USB / Firewire,
etc.)
LWP DokScan for RDP
http://www.lwp.de/distribution/distr_produkte_details.jsp?id=161
(web site in German)
Some scanner models (e.g. HP Scanjet 7400, connected to a
workstation via USB) include network scanner sharing, and are
accessible by terminal server users.
ScanShare Pro from Netcore. It is network device with a network
connection and a SCSI port. You can then access the scanner via
the network.
http://www.netcore.com.tw/product.htm
Vera Noest
MCSE, CCEA, Microsoft MVP - Terminal Server
http://hem.fyristorg.com/vera/IT
--- please respond in newsgroup, NOT by private email ---
"=?Utf-8?B?SmFzb24gRGlldHo=?=" <Jason
Dietz@discussions.microsoft.com> wrote in
news:EF14645C-4DC6-4DC6-8995-0E796732555F@microsoft.com:
> session?
My main issue is that I need to run this USB scanner connected to a Wyse winterm (not a pc) with the software to run the scanner being loaded on the actual terminal services server, not on the direct connect location where the device is connected.
> Possible solutions:
> etc.)
> LWP DokScan for RDP
> the network.
> Vera Noest
> > session?
