Hello everyone,
I have the following situation:
I have a router in my room which supports 100 mbps speeds.
The router is connected to a gigabit switch, and my PC is connected to that switch.
From that switch there is another ethernet cable going through the ceiling to the other side of the house
And another gigabit switch there connects some other PC's and a smart TV.
My goal is to connect the TV to the network with a speed greater than 100mbps
But because the ethernet port on the TV is limited to 100mbps my only option is through wifi.
The room which the TV is in is separated by a few concrete walls and thus when I connect the TV directly to the wifi
Network of my router the signal is very weak.
I want to purchase a wifi range extender of this model: D-LINK DAP-1620 AC1300 Wi-Fi Dual-band
because I saw it supports a wired lan connection of 1gbps for use as an access point.
my question is whether I will be able to get my PC and the TV to communicate at 1gbps speeds.
when I use the extender as an access point and connect my tv via WiFi to it, will the network data ariving from my PC
Get there only with the cables infransracture to the extender, or will it have to pass through the routers wifi,
and possibly limit my speed to whatever the routers wifi protocol can support.
Any help will be appreciated, thank you!
