Using an External DVD Drive for Initial Boot-up
CronsOP
Just built a new PC, and I am completely wiped for cash. I have an external CD/DVD drive that connects with USB. Would that work for the initial boot-up and running the disk that came with the motherboard?
There is a chance. I would have to say it would. Just put the CD in and go to the BIOS then boot options. If it says the cd drive is there then I guess you have your answer 😛 Do you have a 4GB or more USB drive? Just install it with that. It's especially easy with windows 7.
Do I need to install an OS first before installing the drivers that came with the motherboard?
hey i have a cracked version of windows that is genuine somehow and i have it on 2 cd's so one is the crack and 1 is the installation my first question is will i need to get 2 USB sticks? also to put it on a USB can i just drag the files using a different computer on to the USB like drag and drop or so i need to do some kind or extract or burn or something like that because i dont know thank you
