Using an HP ProLiant ML350 G4p as a PC?
S1lv3r_Flame_ZA
7
Hi Guys. :)
I have been given this server to make use of, the trouble is that it is extremely loud and the rack-style case is too cumbersome. I wanted to know if it is possible to take out the motherboard (along with the other components) and put it in a more suitable case, like an NZXT Switch 810 or similar, replace the CPU heatsinks and use one ATX PSU instead of the two that is currently in use.
The system has two Xeon processors (not sure which models), 6 RAM cards (512mb each), 6 HDDs (4x 500GB and 2x80GB), 2 RAID controllers and 2 NICs and 2 PSUs.
I do not need the RAID controllers and I am planning to upgrade the RAM cards.
Please provide any advice, thanks in advance. :)
Hard to tell from the specifications I can find. Try measuring the motherboard and comparing it to ATX motherboard sizes, then look at the wire colors on the psu connectors to see if they match the ATX specification. Redundant power supply is apparently optional on some models of that server, but I don't know how to tell ahead of time whether it is for yours.
Don't wast your time! :) I don't want to be too harsh, but the mobo is not standard size, there are not the right holes for the stand-offs, it has only 2 sata ports, the 6 years old XEONs are really slow compared to a new cpu, you need ddr2 ECC ram for the upgrade and there is much more, like the boot time. Do you have an os running already? Because for some models it's hard to get even the drivers for a non-server os. If you still want to try it, check at least, if it recognizes a graphics card. Some servers don't. It will not run at full speed anyway, because the the pci-e slots are only x8 and x4.
They are, because the mobo has no temp regulation. If you get the hp management software to run, you can choose between two stages: very loud and full speed, the one you have now. :) There used to be a few heatsinks with build in regulation, but will be hard to find today.
No, you can not regulate the fan speed! You can only choose between two speeds and that is very loud and full speed. I have the rack version (HP DL380) sitting behind me and even with the software it is very loud. And i don't think you will have much fun with games on this machine. The performance of the XEONs is very bad compared to a multi-core i3 or i5. But first thing is to get the GTX670 or any other card to run.
I do hope that the software provides even a little help in reducing the noise though.
Its sad to know the dual Xeons won't perform that good. But how would they perform in gaming as compared to an Intel i3 or similar?
I have now managed to replace the case fans on my DL380 with slower quieter fans. I have put in 8 x 3000rpm 20db fans. The DL380 now purrs like a pussycat. However the computer is overheating , so I have now ordered 8 x 4500rpm 30db fans.
The method I used was simple. Based on the advice given by evb, I rewired the new fans exactly as the original fans. I then cut the yellow wire from the fan to the motherboard connector. The part of this yellow wire attached to the motherboard connector was then shorted with the black wires.
The downside of this method is that there is a loss of control sigfnal to the system, but the BIOS can be set to have an orderly shutdown if overheating occurs.
evb's post explaining this method can be found at:-
http://community.spiceworks.com/topic/110762-hp-ml380-g4-way-too-loud-argh?page=1#entry-2569300
