Question Using APC-UPS or Stabilizer for Android Smart LED TV
Aug 17, 2018
17
Hi All,
Could you suggest me the best option from below;
My Items are
1.Mi LED TV 4A PRO 123.2cm (49)
2.Mi Soundbar White
3.Hathway Hi-definition HD
http://www.hathway.com/Digital/DigitalCableTV
4.SYSPRO TURBO STABILIZER FOR LED UPTO 65 INCH (100% COPPER)
https://www.amazon.in/gp/product/B01N2V8THH/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
5. APC-UPS need your advise, which UPS would match my MI LED TV, Sound bar and setup box
Note: Watts & volts info giving the link of the products itself.
Option - 1
STABILIZER -- > TV + Sound Bar + Setup Box
Option - 2
APC-UPS -->T V + Sound Bar + Setup Box
Thanks in advance
Binu
Aug 17, 2018
17
If you have no reliable electricity, UPS is no-brainer.
Now all you have to decide is, what CAPACITY. APC has a calculator. Add up all your pieces wattage requirement, yes you will have to do this yourself.
Hi jsmithepa,
Thanks for the reply.
Tv 109 w
Sound Bar 50w
Setup Box 6w
Total 165 w
please suggest me which model of APC holds good for my requirement and link of the APC calculator...
Aug 17, 2018
17
Hi there.
are you just wanting to protect your electronics?
Fully Yes...
Do you want to be able to keep watching in the case of blackouts/brownouts?
Certain extend..
