Using Apu as a Cpu?
NiteAngels
Commendable
Jun 14, 2016
[strike]Hello there forums. Im currently new to this so apologize for my mistakes.
Now forgive me for being a noob since this will be my pc build. As for this year, Im going to build the following pc with an Apu (A10 6800K).
Apu : A10-6800K 4.1 Quad Core Processor
Motherboard : Asus A88XM-A Micro ATX FM2+ Motherboard
Memory : HyperX 12800/1866Mhz CL10 KIT
Casing : Silverstone PS08B (Black) MicroATX Mid Tower Case
Psu : (I have a 450W Psu that is still working good so I wont be buying a new one)
Hdd : (I still have a 700GB HDD so I wont be buying a new one unless needed)
My main question is that once I have enough money for a GPU , Im planning to buy a Gtx 750Ti. So can I use the APU as a CPU? I dont expect high end gaming since Ive been stuck to a laptop with 15 Fps so Im pretty used to it. I just need something that doesnt suck at a low price. // Yes I do know that the Integrated GPU of the APU will not be in use. // Wont be overclocking so a CPU Cooler isnt necessary at this point of time.[/strike]
//Edit
I have changed my build. Turns out my budget was way tighter. So the A10 6800K build was changed. Sorry everyone but thanks for helping me out. Others who may need help may use the following solution provided. Thanks :)
APU = CPU + iGPU
You can disable the iGPU part of the APU and add a dedicated GPU e.g. GTX750Ti.
Do not forget to unplug the monitor cable from the motherboard and plug it to the dedicated GPU.
And, do not forget to disable the iGPU from BIOS.
Do you already have the A10-6800k or are you getting it very cheap? I am just wondering why you are buying an older APU when your motherboard supports more recent chips. If you're buying chips new the best gaming combination on FM2+ is an Athlon (basically an APU with no iGPU) and a mid range GPU i.e. 750ti/950 GTX/R9 380(not with your PSU) etc.
Thank you for your detailed answer! I hope this helps others who are looking into this matter too!
@Dustybin @Ecky Well Im getting the parts for pretty cheap but thank you for your help @Dustybin! However there was a more detailed and straight forward answer towards my question.
