Question Using Corsair Vengence LED 3200 mhz RAM in Gigabyte GA-A320M-S2H
Aug 15, 2019
Hi,
I am currently using "CORSAIR VENGEANCE LED 16GB (2x8GB) DDR4 3200MHz RAM" in my Gigabyte GA-A320M-S2H motherboard. This ram is not listed under QVL however, I managed to run the ram in 3000 mhz using the xmp profile (but changing ram frequency from 3200 to 3000 mhz).
Now, my PC runs fine for several hours but then it hangs and shuts down. Is it because the VRMs get hot due to the RAM OC? Please note I am using an RX 580 and a Transcend m.2 SSD, both of which make the internal temp of the case very hot. I do not have any intake fan in my case either.
My question is how to make the RAM oc stable temperature wise? Should I put less voltage in the ram (currently it is 1.35v).
Please enlighten me in another thing:
My Ryzen 2600 supports ram by default at 2933 mhz and the ram support of the motherboard is "Support for DDR4 3200(O.C.)/2933(O.C.)/2667*/2400/2133 MHz memory modules"... So shouldn't the rams by default run at something like 2667/2400 mhz instead of 2133 mhz?
