Question Using D.O.C.P stops computer from booting
Jul 22, 2021
14
I have a small problem, i would like to set my Ram to it's max, but after i enable D.O.C.P and restart the pc, it gets stuck in ROG screen and after a few second i can't access the bios anymore and have to restart the pc.
The specs are:
Motherboard : ASUS Rog Strix x570-E Gaming
CPU: Ryzen 9 5900x
GPU: Gtx 970 (I know it's old, but i couldn't find one of the 30 series, without it being way overpriced)
RAM: Patriot Viper Steel 16GB 3600Mhz
Water Cooler: NZXT Kraken x53
Power Supply: Corsair RM850
HDD: Seagate Barracude 2TB (still have to buy an ssd)
Case: Lian Li Lancool II Mesh
OS: Windows 10 pro
Jul 22, 2021
14
Overclock ram manually.
Set timings to 18-22-22-42,
DDR voltage to 1.35V,
Command rate to 1T.
Set ram frequency to 2666mhz, test it.
If all is good, increase ram frequency one step and test again
2933mhz, 3000mhz,3200mhz, 3400mhz 3600mhz.
At some point it will probably stop working. Then return to previous settings, that worked.
Ok thanks, but how do i know how much should i increase the voltage and timing once i go up with the frequency
