I plan to swap from a Gigabyte RTX 3070 Eagle to an Asus RTX 4070 TUF eventually, to avoid dealing with Gigabyte's problems, but I feel like it would be smarter for me to use DDU, since I have 2 drivers for the 3070 installed on this pc that were released before April, and I would rather get rid of them in case they clash with the 4070 drivers.
to be honest, I've never really used DDU before but I know that it is advised to use it in Safe Mode, but I also read that you should disconnect from the Internet as well; however, whenever I try to look into the reasoning, it always comes up with AMD-based problems. I'm aware AMD and Windows have a weird issue with Windows replacing the drivers all the time and I assume it is advised to disconnect from the Internet to prevent Windows from auto-installing a different driver, but is this necessary for Nvidia?
do people recommend disconnecting your Internet connection due to the AMD-Windows problem, or is that something you should for an Nvidia GPU as well? because I haven't personally seen ANY Nvidia user with the whole "Windows replacing drivers at random" issue. will I need to do this as well, switching from a 3070 to a 4070? I plan to install Driver Version 531.61 first, rather than the direct latest driver, since 531.61 is the release/support driver for the 4070. although if anyone knows of a better, more recent and stable driver for the 4070, I'd be happy to know
side question: if I do have to disconnect my internet, I have an Ethernet connection; would it be effective to just turn off my router before using DDU? would that be enough to disconnect my internet connection and safely use the uninstaller?
