Hey Gurus:
Maybe you can help a gal. I had Verizon DSL (which was a DSL modem with wireless router built in). I've canceled DSL a long time ago and just used the wireless portion of the router (for my printer basically).
Now I've moved and have cable internet (using a Motorola SB4200 Surfboard Modem). I plugged the modem into my Verizon DSL Wireless Router hoping to use the wireless portion. No luck.
Am I doing something wrong? I figured sometimes both routers try to sit on 192.168.1.1 so I changed the Verizon DSL Wireless Router to 192.168.2.1. Still no dice.
Any ideas?
Oh, also I went into the wireless router's config and I turned the DHCP settings to off.
Help?!
By the way, my desktop is working (is plugged into Verizon DSL Wireless ROuter) which is hard wired with ethernet. My laptop is connecting to the Wireless ROuter okay, but no internet.
Any ideas?
Help?!
