using gpu while having vga port plugged in MB
Dec 29, 2018
8
I was just wondering if i can still use my gtx 1050 ti while not having the monitor plugged in to it because it supports vga and the gpu doesn't have vga port.
Is it possible?
If not, can someone provide a link to an adapter that turns vga into hdmi?
Any help would be appreciated!
You will need either an active DVI-D,HDMI, or Displayport to VGA adapter/converter. There are no legitimate 1050Tis that support analog(VGA) displays.
https://www.amazon.com/Active-Adapter-Benfei-Converter-Gold-Plated/dp/B01KLKQN9U/
https://www.amazon.com/VicTsing-DisplayPort-Adapter-Gold-Plated-Converter/dp/B06VWCB587/
https://www.amazon.com/Active-DVI-D-Adapter-Benfei-Female/dp/B07D3XZ9SD/
