Using Headphones and Mic with only 1 audio jack
Yes
Would this be good?
https://www.amazon.ca/3-5mm-Female-Earphone-Audio-Splitter/dp/B00S0RWKAS/ref=sr_1_9?s=electronics&ie=UTF8&qid=1458734320&sr=1-9&keywords=headset+adapter
just looking for something that won't eat up all my $$ on amazon
Your adaptor splits one into two, wrong. the one Phillip posted is what you want takes your two plugs and makes them one, just as you needed for the laptop. This one is cheaper........https://www.amazon.ca/Startech-Com-MUYHSMFF-Muyhsmff-Splitter-Adapter-M/dp/B004SP0WAQ/ref=pd_sbs_23_1?ie=UTF8&dpID=41WCy3b0sCL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=ZP6A64FKKPCBYWK370RH
Can yo ulink me something more cheap?
Yes
