Question Using LenovoY410p, after replacement HDD by WD10SPZX
Jul 30, 2019
i just bought WD Blue 1 TB (WD10SPZX) to replace my current HDD (ST1000LM024) , but afterchanged, i got this PXE-M0F: please check your cable.
i already trying to switch between legacy and UFFI , also sata mode from AHCI and compatible, but not working at all
my window is installed in another drive ssd , this hdd drive is just install some programs.
i already attache picture in this post, please help.
if i use my old hdd, it work fine, but when i change to new hdd , it stuck this black screen.
problem : View: https://i.imgur.com/1q5Cf1v.jpg
BIOS :
View: https://i.imgur.com/HO6GyCm.jpg
View: https://i.imgur.com/6rIjo6S.jpg
View: https://i.imgur.com/XmLaIf5.jpg
old hdd : View: https://i.imgur.com/tjuX3oK.jpg
new hdd : View: https://i.imgur.com/fsKujYM.jpg
if you put the old hdd back, did it boot?
did you install windows with the old hd attach?
if put old hdd back, it work fine. i installed window in ssd but not in the old hd.
i just tried change my new hdd to logical drive same as my previous old hdd, but not work at all.
i already tried my new hdd in external box and connect via USB, it work fine, i can format or adds file into drive.
i just looking at disk management and i saw Boots, Page file, Dump, Primary Partition on my SSD and System, Active, Primary Partition on my old HDD, is it because of this ?
then if i want to use new hdd , i have install new window? or there are any other methods ? because i don't want to format my ssd , many works there.
