Hi all,
please be patient with me, I'm not a network expert but a beginner, also forgive my English I'm Italian speaking.
Note that this is just a temporary configuration though...
I have a modem/router handling my DSL connection already. I added a Linksys WRT350N (I had it for free) which I want to use as wifi access point and ethernet switch only (but I plan to buy a separate switch soon). Therefore, I have connected both devices in a same network, i.e the router has static IP 192.168.1.254 and the Linksys 192.168.1.253 and the router is connected to one Linksys LAN port, NOT to the WAN port of course. I prefer this setup ways more than useing a bridged connection. This way my modem/router handles the Internet connection and routing, also I can access BOTH devices configuration pages from my network without need to drive a cable to the modem/router directly everytime !
BUT I'm not sure my setup is optimal, even if everything apparently works. For example, can I be sure that this way I am not experiencing double NAT, or other conflicits ? And that the Linksys
connected this way actually STOPS operating as a router, as I require ?
If I try to disable the NAT in the Linksys, I am forced to insert at least one static route and I
honestly must stop there cos I'm not an expert, as I said already.
What shall I do ? Can I let my setup this way or I must try to disable the NAT and specify a static route in the Linksys ??
Thanks u very much for ur support
