its not a 6+2pin tho btwThe 8 pin should work on one of the 6 pin
Never use cables extension like molex.. get a decent psu..
Let's see the cable and exact power supply. An 8-pin PCIE cable that isn't a 6+2 pin is uncommon.
Yup, that doesn't appear to be a PCIE cable.
If that's not a PCIE cable, if you plug that in, you may no longer have a GPU.
Again, what's the exact power supply? I asked this question for very specific reasons.
does using a ups make a difference tho i bought this powersupply because my fsp broke down in the middle of quarantine here.Yikes, I wouldn't use this dodgy off-brand PSU in any PC, let alone one with a GPU that needs multiple supplementary power connectors. I sure as sugar wouldn't add a second fire hazard in a Molex adapter to a PSU that's already a fire hazard.
Hard no here.
No.does using a ups make a difference tho i bought this powersupply because my fsp broke down in the middle of quarantine here.
okay okay thank you dude but do you have any recommendations on a cheap budget psu? im running an a320 chip with 8gigs of ddr4 and an amd a8 9600No. A UPS can't make a cheap, dangerous power supply into a safe one.
Quarantine or not, this has no business being used. If replacing a PSU during the quarantine is difficult, replacing and diagnosing other fried components will be even more so.
The box it came in is much more useful than the PSU is.
okay okay dude thanks for the suggestion ill look into itI'm not sure if people will agree with me, but you could go for the Corsair VS650. People say it's kinda bad, but I've been running it fine for 2 years, with the only problem being that cable management is pure hell due to it not being modular. It's also fairly cheap.
VS series in general is fairly cheap.If it's a new one without orange or green lettering, it's probably* absolutely fine for a build like this in a pinch.
* Probably because I still don't know the GPU, which is the key bit of information here
