Hi everyone !
I have an old pc which I use throughout the night as a download client.
It have no internal network card, and the routers are so far that I must use wifi.
So I use a USB network adapter to connect.
Thing is, when I leave it to download over the night, sometimes I wake up finding that a disconnection happened early on, resulting in a waste of pc usage over the whole night.
So I wanted to use 2 adapters instead of 1 to ensure that if one of them disconnected the other will carry on.
How can this be achieved ? will one of them override the other and cancel the effect of the one with the smaller bandwidth ?
I should also mention that when I tried to connect using both adapters (bearing in mind that both drivers & respectful apps are installed) there was no internet connection, although when I connected with only one of them, it worked smoothly !! Is that normal ?
The 2 network USB adapters are:
-LogN Wireless lan adapter
-TP Link TL-WN723N 150Mbps Mini Wireless N USB Adapter
*using Windows 7 86x
Thanks a ton !!
Thanks a ton !!
