Hi,
Hope everyone is staying safe.
I was wondering if there were any tweaks for what I should disable or what I should keep enabled when using my netgear Nighthawk Router (r7000p) as a wired router. Or any tweaks that will speed up the router. I already have it overclocked a little bit I believe. Is there any website or anything like that. For example (Cts Protection Mode) Should I have that enabled or disabled I'm on just a wired connection all by myself using 1 computer windows 10 and that's it. No other users nothing. Also Tx power should I raise that It's at Auto now if I go to manual it's at 71. Should I raise it from that to maybe 100 or 200. Or does it have no affect on a wired connection. I'm not using wireless or wifi at all I have all wireless disabled in dd-wrt.
Thank you!!
Thank you!!
