Using Netgear wndr3700 as router extender problem
Kazzz2017
Hi everyone.
I have a cable broadband connection and am using the router supplied by the ISP in WiFi mode, this is connected by wire to the computer and to a powerline adapter. The powerline is setup between room 1 and room 2. The powerline in room 2 is connected to a Netgear WNDR3700 (in the LAN port), then another lead from the netgear (LAN port 2) going to a second computer in room 2.
So room 1 powerline is connected to room 2 powerline and room 2 powerline is wired to the netgear router which is wireless.
Now the issue is the WiFi connection stops working on the netgear after a while. I am not sure why, I have ensured DHCP is turned off on router 2 (netgear) so that router 1 can assign these and that router 2 has a static IP and this is outwith the range assignable by router 1. What happens is that devices connect to the router but don't get an IP address assigned.(i.e. does not get past obtaining an IP address)
If you need any more info let me know or if any of this is unclear.
Any help please?
Thanks
It should be as simple as that and work properly. I assume you mean only wifi that devices wired to the second router work fine.
Try to manually assign a IP to one of the wireless devices and see if it is just DHCP that is not passing or if it is all traffic.
It almost has to be a bug or some other failure in the netgear box. The wifi and lan ports should be connected and allow all traffic to pass between them. Even if you wanted to it tends to be almost impossible to filter traffic between the lan and wifi so I can't see it being a configuration issue.
