G
Guest
Guest
Archived from groups: alt.internet.wireless (More info?)
I need to find out if it is possible to use Power over ethernet to power two
devices from a single ethernet cable. I forsee a relatively standard POE
setup at the injector end. Then at the location of the first device needing
ethernet connection and power, put in an ethernet hub before the power is
split out. One ethernet output (with power ) from the hub goes right into
the POE splitter and then provides ethernet (w/o power) and power to the
first device. The second ethernet (with power ) from the hub goes on to the
second device and connects to a standard POE splitter to provide power and
ethernet to the second device.
Plan is to use Linksys POE devices to power two WRT54G Access Points.
1) Will a passibe two port hub handle all wires in the cable including the
ones with power?
2) Does the Linksys POE injector supply enough power to power two WRT54G
devices?
Better way to do this?
Bob Alston
Home: 918.494.4913
Lake: 231.893.8044
BobAlston9@AOL.com
http://members.cox.net/tulsaalstons/
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.737 / Virus Database: 491 - Release Date: 8/11/2004
ones with power?
devices?
Bob Alston
Home: 918.494.4913
Lake: 231.893.8044
BobAlston9@AOL.com
