Question Using RGB fans without a PC
Oct 13, 2019
Hello,
Maybe a weird question but, is there a way to use RGB fans without using a computer. I was thinking of using a RGB controller in order to control the LED`s but how do i power the fans itself.
Maybe i am overthinking this but i am kinda stuck, please halp!
Thanks in advance,
Regards,
Vincent
its 12volt, any 12volt dc adapter will power it, just make sure amperage is same or above your fan
Thanks for the reply. Isnt there allways a cable to power the leds and a cable to power the fan? The leds are easy to connect to a controler but how about the fans? The connectors are ment for a motherboard right?
Regards,
