T Timtam95801 Commendable Jan 23, 2017 1 0 1,510 Jan 23, 2017 #1 So in the Overwolf app there is a option to record using your gpu, If I get SLI GTX 970's, when I record will I get the same performance as having just one gpu with a little boost or what, just a little curious.
Solution ak47jar3d Jan 25, 2017 Over wolf doesn't work properly with sli enabled. It's not coded to take advantage of both gpus.
ak47jar3d Champion Mar 3, 2014 7,112 61 54,590 Jan 25, 2017 Solution #2 Over wolf doesn't work properly with sli enabled. It's not coded to take advantage of both gpus. Upvote 0 Downvote Solution
mlga91 Admirable Jul 8, 2014 2,545 0 7,960 Jan 25, 2017 #3 Why dont you simply use shadowplay? it records gameplay without any notable (or any at all) performance loss. Upvote 0 Downvote
