Using the Same OS on Another Drive?
l0lapple
64
I want to change (upgrade) my drive and using the same WIN 8.1 key. Is it possible toI format the current drive and use the key on the new one without having to buy a new key?
If this is in the same system, other than the actual drive, yes you can.
If you've changed other parts as well, like the motherboard, no, you can't.
