Using Thrustmaster TH8A Shifter with Logitech G25 Pedals and Wheel?
subwayrat82
Hello,
I have a custom-built Kenworth gaming simulator rig for American Truck Simulator, and I want to upgrade the shifter of my Logitech G25 to a TH8A, but want to retain the original wheel. Is it possible to connect the TH8A to these? Would the TH8A be considered a separate controller, or will they just be daisy-chained the way they are by default with the Logitech components?
Thank you!
Mike McGuire, in Frozen New Jersey
MERGED QUESTION
Question from subwayrat82 : "Using Thrustmaster TH8A Shifter with Logitech G25 Pedals and Wheel?"
Hello,
I have a custom built Kenworth simulator racing rig, that I use a Logitech G25 wheel, shifter and set of pedals with, but I am interested in upgrading the shifter to a Thrustmaster TH8A, while retaining the wheel and pedals for now. Is it possible to connect the TH8A to the other components in daisy-chain, like the way the components of the G25 are? Or does the TH8A need to be set up separately, as a separate controller? Would I need to jumper the pedals and wheel directly to the computer, bypassing the connection to a shifter, where the logitech shifter used to be?
Thank you,
Mike, In Frozen New Jersey
