Using tp tl-r470 load balance router with adsl router
Aom
Now i have two internet adsl routers not adsl modems , can i bundle them using the tplink tl-r470 load balance router ???
thx
Waiting for ur tips
Yes but I suspect it does not do what you think it does.
This type of router does not let you combine the connections to increase the bandwidth in the way most people want. Say you have 2 2m circuits. It is not possible to watch a netflix movie that needs 4m but you can use both connections at the same time to watch 2 2m movies.
Even then these routers can only do so much there are many site that will cause trouble. A example say is a gaming site. It has a login server and a bunch of game servers. If it would use connection 1 to go to the login server and then use connection 2 to go to the game server the game company would detect this as hacking because you are coming from 2 different IP addresses.
The router can not...
The router can not possibly know these relationships between servers in the internet. Even in normal web pages data is coming from many servers even though you only typed in a single url name. You can to a point configure this in the router but it quickly becomes tedious.
What most cheap load balancers do is say computer 1 in your house always uses connection 1 and computer 2 in your house always uses connection 2. It means many times one connection may be over used and the other idle.
This is why companies like bigip can sell $10,000 F5 load balancers. Even these can not solve all the issues with out some custom configuration.
hi i got the tplink 470.... was able to combine the bandwidth..... was able to increase my download n upload speeds aswell.... the only issue i face is when i try to download anything from gaming srvers its gets disconnected....
please help!!!
thnx
This is because you only THINK it increased you upload and download speeds it is a technical impossibility. The solution is to force it always use 1 connection when talking to a particular site so the ip address does not change.
