Using Two Wireless Routers To Cover Dead Zones
Mar 29, 2018
Greetings, I have an Edge Router Lite 3 set-up as my router and an Ubiquiti AP handling the wifi. This set-up works, but even though I have the Ubiquiti AP placed directly center of my home, I have one corner that is constantly a "dead zone" I was thinking would it be possible to run an Cat6 cable from my POE Switch to set-up a second router (Sagemcom Fast5260) and essentially use this as "wifi" for the "dead-zone"?
The caveat or potential "hiccup" that I see is I have a DLNA server set-up on the "primary" wifi that I would like to be able to access if a device crosses over to the secondary network. I.E. DLNA server running on Wifi1, but if a user connects to Wifi2 - I would still like to be able to access the DLNA server.
You should be able to disable DHCP by going to Router Settings, then the DHCP tab.
Then connect a network cable from the switch to a LAN port (not the WAN port).on the Sagemcom.
Should look similar to this:
As long as the Sagemcom is properly configured to act as an AP only (routing disabled/unused), then your DLNA server will be seen as being on the same subnet as any device connected via the Sagemcom.
This forum sticky provides a guide on how to configure any router as an AP.
http://www.tomshardware.com/forum/36406-43-convert-wireless-router-wireless-access-point
I am not seeing an option in the web gui for the Sagecom to configure it as an AP nor do I see the ability to disable DHCP. Are there other options for me to achieve such?
