uTorrent running in background but not opening.
bjwest1977
19
Hi,
From time to time while running uTorrent (pinned to the taskbar) I will click on uTorrent to check on my downloads and the program won't open.
If I hover over the pinned icon it brings up a small screen showing that the program is running but I can't get to full screen view of uTorrent.
I do find it does regularly come up with "not responding" as well.
Any fixes available?
Without rushing to judgement, there are valid uses for uTorrent that does not include piracy.
I would suggest uninstalling the version you have now and try re-installing the most recent version.
That's one way of doing it. However I would recommend closing all instances of uTorrent via Task Manager and then running it again. If this doesn't work, then you would have to reinstall the most recent version.
This thread is over a year old.
Closing.
Wolfshadw
