Hello people of the forum. I finished properly building my new rig and have found out how difficult it is to test if it's running in optimum performance.
One of them is how people would refer to their temps using coolers on i7. So does anyone know what people generally refer to when measuring their temps. For example all the reviewers for http://www.newegg.com/Product/Product.aspx?Item=N82E16835103055 who state they have like below 30 C IDLE temps and some say like 35-40 C. Most of them are running on stock and then some OC'ed and getting saying they have temps of 35ish temps idle @3.8ghz or whatever.
What ARE the temps supposed to be?
Because I dunno if they are referring to CPU temps or like average core temps like CPU #1,#2,#3,#4.
Also please those of you who have v8 cooler master and core i7 post your own temps so I can compare mine.
Currently mine is cooling the i7 920 stock@ CPU = 21 C CPU #1,#2,#3,#4 average = 36 C
Measured using Lavalys EVEREST ultimate edition, EVGA Eleet tool, Real temp 3.00
I'll be checking this post tommorrow since it's late and I have work tomorrow.
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case
EVGA 132-BL-E758-A1 LGA 1366 Intel X58 ATX Intel Motherboard
EVGA 01G-P3-1281-AR GeForce GTX 285 1GB 512-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920
OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model OCZ3G1600LV6GK
Western Digital VelociRaptor WD3000HLFS 300GB 10000 RPM SATA 3.0Gb/s Hard Drive
COOLER MASTER V8 RR-UV8-XBU1-GP 120mm Rifle CPU Cooler
