Vacuum cleaner as a blower for dust?
junred56
78
Okay so, I'm tired of using compressed air when cleaning my pc because, well, it runs out. I know that vacuuming the inside of your PC isn't a good idea because there's gonna be static build up in the nozzle because of all the dust. BUT, I was wondering, in the same way as an air compressor or a can of compressed air, is it okay to use a vacuum cleaner as a blower so I can use it to blow dust off my PC?
If you cleaned it really well it might work for the very loose dust. If it's not cleaned your probably blowing more dust in than you are blowing out. My experience with cleaning my PC with air has been duster cans, a leaf blower, and an actual air compressor. I'll be honest, buying cans of air sucks, but it still works the best. But to be clear, yes it should be fine to blow air on your PC with your vacuum. Just make sure its been cleaned first so that you don't do more harm than good.
Yes you can use blowers to clean the PC but they won't be nearly as effective as compressed air. A cheap leafblower or even a hair dryer (set to non-heating) will clean away large masses of dust just fine, but the little bits of dust you can only clean with the high pressure of compressed air.
