Try removing the battery and cleaning the contacts on the battery and in the laptop. When you reinstall battery make sure it's firmly seated. You can also try wiggling it a bit to see if that makes the connection. Otherwise, you can try a new or different battery. If none of that works, you've probably got a loose connection somewhere in the case.
