VAIO Screen does not load
Viaoquestion
4
My Vaio Desktop opens up and starts with green lines boxed around the VAIO symbol then has green to white lines across the screen. After loading the screen turns blank. At first the screen when i was using it would turn blank and then turn back on and the system said it had to recover it. How do I get my computer to work? Do i just need the computer repair cd?
If your system is a PC:
Try using another Monitor, or Plug your Monitor into another PC.
Remove, Video card, dust off & reseat card.
If Laptop: Try plugging in an external monitor.
Can also check Event Viewer for possible errors.
The fact it worked once in Safe Mode indicates to me, hardware issue.
May have the monitor or video card going bad.
Can you boot into safe mode and do anything ?
I've tried to open the option to safe mode but I've only gotten it to work once.
Thank you sooo much!
