Question Valorant doesn't run fast enough. Help.
punkncat
Champion
Ambassador
I am not aware of a way to OC the A8 you have on hand. This is a CPU that wasn't particularly strong when released and certainly hasn't aged out well.
What are you trying to do with it that you feel an overclock is desirable?
Oct 3, 2023
I am trying to run valorant at atleast a steady 60 fps, i can get upto 40- 45 at the moment
My tempreture is at 50 degrees C so i know there shouldnt be any issues have i oc it
punkncat
Champion
Ambassador
I didn't note your having a graphics card. Isn't the R7 listed in the above link just the integrated graphics?
If my hunch is correct, you could try a discrete graphics card if your build has room. Other details seem to indicate this may be a Lenovo prebuilt?
These chips also benefitted from really fast RAM, but that may be limited by the motherboard. Considering the age of the system I would not spend anything towards trying to improve it rather than putting towards even a more powerful used system.
Do you have any manner of budget for upgrading?
Do you have the specific model information of the PC you are asking about?
