Question Valorant Low FPS
Gamer_DeepYT
12
So i have an
AMD Ryzen 5 1600
Asus Prime B350 Plus Mobo
Corsair Vengeance 16X2 2400MHz
Asus Dual Rx580 8GB
Gigabyte P550B PSU
I used to get 260+ FPS on 1920x1080 low settings
But now I'm getting 150 or lower and it's fluctuating between 80-150
I switched to 1440x1080 same results
I tried to max the settings still I'm getting 80-150 constantly fluctuating
I reinstalled windows and drives
Everything is updated
My disks are clean and have 70% - 80% free space
With youtube Optimisation guids and without optimization I'm getting same performance
I don't have any viruses or anything running on BG.
I Play for a team and trying to go pro and it's very tough for me to do my best.
I hope you guys will help me fix this issue.
Thank you guys in advance.
So i have an
AMD Ryzen 5 1600
Asus Dual Rx580 8GB
Gigabyte P550B PSU
Valorant is a bit unoptimized for now, even my friend using r5 3600 wont get past 230fps with drop as low as 150fps
but try these step by step:
  • Disconnect from internet
  • Uninstall gpu driver using DDU (clean and do not restart).
  • Uninstall all the processors on device manager (should be 12 on yours) like this:
  • Restart the pc to bios, and update to the latest bios(download, extract the files and copy it to flashdrive, plug it on top rear usb slot then reboot to bios and flash the bios). Then go to bios again after update and load default or optimized settings.
  • boot up to windows and install the latest AMD Chipset driver, reboot, go to power plan, choose amd ryzen balanced, and connect to internet.
  • Install the latest radeon driver.
    *do this all offline until reboot after installing amd chipset driver, also you may reboot to bios after all of this to set the XMP (and previous settings you did in the bios), make sure your ram is on slot 2 and 4. Download needed files (highlighted word) before doing step 1, do the step by orders.
    If razer synapse the issue, it's better to disable it.
  • And check windows update (and optional updates) if there is any, install them all (except for chipset driver)
Make sure the psu connected to the gpu is 1 pcie cable per 1 slot (use main cable, not the branches/split) like this:
