Vaping causing 3 beep, loud fire alarm like sound from pc
Zenreality
Commendable
Dec 2, 2016
Has anyone heard of this and is there a way to disable it? When im on my pc and I don't have my ceiling fan running when I vape it randomly sets off the alarm. Any help would be appreciated.
The PC runs fine and no failures during the beeping. Using HWmonitor all my temps are excellent at the time of the beeps.
You probably shouldn't vape in the same room as your PC. I know nothing about vaping, but if the smoke gets into the PC, it can cause moisture and potentially damage some parts. To fix the issue, just don't vape in the same room as your PC.
Latest posts
