hi my name is ryan im 14 and im not a basic user but im not an advanced user and i built a desktop pc at christmas and all i have had is trouble. firstly here is my specs
CPU: AMD Athlon II X4 760K 3.8GHz Quad-Core Processor
Motherboard: MSI FM2-A75MA-E35 Micro ATX FM2 Motherboard
Memory: Corsair Vengeance 4GB (1 x 4GB) DDR3-1600 Memory
Storage: Western Digital BLUE 1TB 3.5" 5400RPM Internal Hard Drive
Video Card: Sapphire Radeon HD 7750 1GB Video Card
Wireless Network Adapter: tp link TL-WN821N
Case: NZXT Source 210 Elite (White) ATX Mid Tower Case
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply
Optical Drive: Lite-On iHDS118-04 DVD/CD Drive
Operating System: Microsoft Windows 8.1 - OEM (64-bit)
1. i got stuck in a preparing automatic repair loop sraight after install so i had to reinstall from scrath and reinstall drivers
2.then i had a few bsod (KERNAL_SECURITY_CHECK_FAILURE and a few others) and i got onto windows and they told me to do a reinstall so i did
3.this is my 3rd reinstall and im getting various bsod originaly i had everthing from the following
-DRIVER_OVERRAN_STACK_BUFFER
-SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
-MEMORY_MANAGEMENT
-SYSTEM_SERVICE_EXCEPTION
-BAD_POOL_CALLER
-BAD_POOL_HEADER
-NTFS_FILE_SYSTEM
-PAGE_FAULT_IN_NONPAGED_AREA
PFN_LIST_CORRUPT
but since i have done the following
-sfc /scannow (system file scanner could not perform the required action)
-windows defender scan (clean)
-gpu driver update (done )
-ccleaner (registry and cleaner )
-defragler (done )
-windows update
-chkdsk c:/r
-chipset drivers (done but dont know how to check if they are up to date live update says i need to install them but i did)
-hd audio (done)
-memtest 7 pases (done no errors )
-wd hdd test (done no errors )
-ethernet drivers (even though using wireless dongle )
-malwarebytes (REMOVED 32 MALICIOUS FILES )
ok so after i though i have gotten rid of all those bsod because of the malware bytes scan
BUT THEN when i tried to play warframe BSOD MEMORY_MANAGEMENT since then i have had 9 of those over the last two days so i think i removed the other ones
WHAT COULD THIS BE I HAVE TRIED NEARLY EVERYTHING BAD SATA CABLE BAD HARDWARE I HAVE RAN OUT OF IDEAS PLEASE GIVE ANY SUGGESTIONS AND THANKS IN ADVANCE
had MEMORY_MANAGEMENT again but only happen when i started stem downloading ????
P.S I WILL BE POSTING THIS ON A FEW FOUROMS BECAUSE I AM SO DESPERATE
-MEMORY_MANAGEMENT
-BAD_POOL_CALLER
-BAD_POOL_HEADER
-NTFS_FILE_SYSTEM
PFN_LIST_CORRUPT
-defragler (done )
-windows update
-chkdsk c:/r
-hd audio (done)
