Hello, I have been out of the game for a little while. I used to play around with this stuff more. Anyway I want to do a very "mild" air overclock. I got this K chip for "Free" mhz" and to do some things a little faster(not much of a gamer)
Intel extreme tuning utility or bios. I have tried both and it looks like their doing the same thing.
I have been reading a lot and trying not to be guy who missed something easy in the FAQ.
http://www.anandtech.com/show/9483/intel-skylake-review-6700k-6600k-ddr4-ddr3-ipc-6th-generation/6
https://www.itrw-pc.com/featured/pushing-the-limits-intel-skylake-i7-6700k-overclocking-guide/
Setup: http://pcpartpicker.com/list/nxzFGf
Overclock Goal: 4.4 to 4.5 on air cooling and safe and reliable temps
I know I don't have the best system ever and no water cooling, but I hope my goal of 4.4 or 4.5 is reasonable on a budget H5? Please tell me if it is not.
I tried moving the multiplier to 44 or 45 then manually set my voltage. Around 1.25 I believe is what I chose, then I hit apply. I have also tried the same settings in "bios" Then looking at my CPU core it goes up to 1.392 and VID jumped to max of 1.458 according to HW montior. I do have the core voltage mode set to default of adaptive. I understand it wont' be perfect but it seems something is off. I quickly changed it back to "stock".
Why would it jump that high if I set it up 1.25? Is HW monitor not working with this chip?
According to that andtech article, I should be able to do 1.250 voltage for 4.4. That seems reasonable, but why does my bounce around so much higher than that?
https://s31.postimg.org/kfynzcguz/vid_temps.png
I want reliability and stability, but I don't think 200-300mhz should effect me in the long run if I can keep my temps in range. My goal is to stay under 75C. My system is rock solid so far, so I don't want to spend hours and hours is this possible? I have read several similar threads, but still don't see the answer I think I should be getting.
If I can't I wont' lose a ton of sleep this system if fast, however I paid extra for this stuff and thought I would get 5-10% out of it.
I appreciate any supportive feedback in advance.
Some threads I have looked at so far:
http://www.tomshardware.com/answers/id-2988234/6700k-voltage-tweaking.html
http://www.tomshardware.com/answers/id-2989186/6700k-voltage-fixed.html
http://www.tomshardware.com/answers/id-2773198/intel-6700k-voltages.html
http://www.tomshardware.com/answers/id-2946975/6700k-safe-overclocking.html
http://www.tomshardware.com/answers/id-3130288/temps-6700k.html
http://www.tomshardware.com/answers/id-2813756/cpu-voltage-higher-set.html
https://docs.google.com/spreadsheets/d/1wQwYMGsSnMpKxrEesNVUSoP7hGykFWw1ygJsxwx64e8/edit#gid=0
http://www.tomshardware.com/answers/id-2950126/6700k-skylake-voltage-temps.html
http://www.tomshardware.com/answers/id-2993956/6700k-overclocking.html
http://www.tomshardware.com/answers/id-3081417/6700-overclocking-question.html
http://www.tomshardware.com/answers/id-2979184/overclocking-6700k-time.html
http://www.tomshardware.com/answers/id-2885213/confused-6700k-overclocking.html
http://www.tomshardware.com/answers/id-3074243/overclocking-6700k-past-6ghz.html
http://www.tomshardware.com/answers/id-3072951/6700k-safe.html
http://www.tomshardware.com/answers/id-2935529/6700k-overclocking-couple-questions.html
http://www.tomshardware.com/answers/id-3031909/problem-overclocking-6700k.html
http://www.tomshardware.com/answers/id-2998986/6700k-slight-overclock-adaptive-voltage.html
http://www.tomshardware.com/answers/id-3044709/6700k-overclock-alright.html
http://www.tomshardware.com/answers/id-2808863/cpu-results-skylake-cpu-6700k.html
http://www.tomshardware.com/answers/id-3103090/win-silicone-lottery.html
http://www.tomshardware.com/answers/id-3133473/cooling-option-overclock-6700-cpu-mhz-4mhz.html
