G
Guest
Guest
Archived from groups: rec.games.vectrex (More info?)
Hello All,
A little/big problem with a vectrex I have. Screen is intermittently
working and I am not sure the reason why. On several occasions I have
turned the machine it has worked fine, when I turn back off and plug
cartridge in the screen does not work - sound present but no display. Take
cart out and turn on to see if Minestorm works - but no go also. I have
turned the brightness up and notice that there is a very small white line
part way across the middle of the screen left to right. There is 'movement'
visibly in the line, that is I can see the line flicker when I am shooting
in minestorm.
Any ideas, or can someone point me in the right direction?
Cheers,
CM.
Hello All,
in minestorm.
Cheers,
CM.
