A adgonta Commendable Aug 25, 2018 74 1 1,635 Oct 8, 2018 #1 Whats the highest resolution that the Vega 8 integrated graphics can reach ? I want to use it for 3 months until I get a dedicated card . Im going ulteawide with 2560*1080 ? Will it support that resolution ?
Solution rgd1101 Oct 8, 2018 look at motherboard spec. http://www.tomshardware.com/forum/id-3683764/144hz-apu-ryzen-2200g.html#20940359
rgd1101 Don't Moderator Nov 7, 2011 74,862 4,252 176,290 Oct 8, 2018 Solution #2 look at motherboard spec. http://www.tomshardware.com/forum/id-3683764/144hz-apu-ryzen-2200g.html#20940359 Upvote 0 Downvote Solution
A adgonta Commendable Aug 25, 2018 74 1 1,635 Oct 8, 2018 #3 Does the ASRock B450 pro 4 work ? On the site it says it has max 4k at 24 fps and 2k at 30 . *It also has display port 1.2 . Upvote 0 Downvote
rgd1101 Don't Moderator Nov 7, 2011 74,862 4,252 176,290 Oct 9, 2018 #4 By the spec, should be able to Upvote 0 Downvote
