Velcro for cable management inside PC
Mathbot2000
22
Hi all,
I'm about to start my first assembly in the next few days, and I'm looking into cable management options. Velcro ties look great for outside of a case; are they also ok inside a case? (Something like this: http://www.amazon.com/VELCRO-Brand-ONE-WRAP-Self-Gripping-Reusable/dp/B001E1Y5O6/ref=sr_1_1?s=electronics&ie=UTF8&qid=1415728110&sr=1-1&keywords=cable+ties)
I'd rather use those than zip ties, as long as there aren't any concerns about velcro ties damaging parts.
Thanks!
I have used velcro ties for temporary cable management and it works fine. I mainly use them for massive wire snakes or to tie down something I know I will be replacing, but I use zip ties to tie cables to holes or other dedicated cable management points. Certain cases might have loops that are only big enough to slide a zip tie through. In tighter areas, it might be a better option to use zip ties simply due to the lower amount of space they take up. They are also dirt cheap too, a couple bucks for a pack of a hundred. Back on topic, no, I have not had any issues using velcro for cable management.
Sounds great, thanks!
