Fire Range is the codename for AMD's "Ryzen 10000" (or however they brand it) APUs, which will come with high-performance RDNA-based graphics and an XDNA-based NPU. These chips will be the successor to AMD's recently released Ryzen 8000G (Phoenix) desktop APUs and are expected to use a monolithic die just like all of AMD's current and previous APU designs.
I'm sorry, but the above info is NOT correct. The upcoming "Fire Range" APU will sport a multi-chiplet design/chiplet-style architecture. Not monolithic.
These chips are going to be high-end mobility offerings succeeding the existing
Dragon Range HX lineup. Just like Dragon Range, these chips will be using desktop-grade chiplet dies. These are also not direct successor chips of the Phoenix desktop APUs either, and in no way AMD will brand them under Ryzen 10000.
"Ryzen 9055HX" series nomenclature sounds more plausible. These mobile chips/APUs will use the same Granite Ridge desktop silicon.
Also, it is highly unlikely these chips will use "
high-performance RDNA-based graphics" as the article claims. Nope. With the Dragon Range lineup, AMD went for a very modest/weak "2 CU" configuration even on the flagship
7945HX SKU, based on the RDNA 2-based
610M iGPU.
So expect the same from Fire Range lineup as well. You may ask why ?
Because, these HX-series chips are meant to be paired with discrete GPUs for graphics-intensive work. After all, these are desktop replacement laptop chips.
